Transducer placment
whistler
The BlueGrass State
Looking around for the best place to mount a transducer. I think they say to stay 15 inches away from the engine area. Giving that info the first place I have to mount a transducer is between two strakes and right inline with a bunk board. I would like to use this spot and don't think it will ever contact the bunk but there is that remote possibility. The transducer looks like it's designed to fold up if it strikes something but is this reliable? The only time it would make contact with the bunk would be during loading. The next spot I could mount it is between the last strake and the chine. I'm concerned the chine will cause a problem and definitely be more susceptible to times when the transducer doesn't won't work due to the tipping in and out of the water during turns. I think I've covered all the bases so give me your thoughts.
I ran across the same problem because I dry stack my boat and I didn't want those guys to rip off my transducer with their fork-lift. The flip up mount is designed to flip when struck by something, but it depends on plastic tabs that are molded in the mount to secure it in place. It looks like those aren't built to take many hits before they wear down or just break off. I had the mount shown below made so that I could remove the transducer and lay it in the transom area when I finished with the boat. Everything is adjustable so once I got the depth setting correct for the transducer, I tightened everything down and when I put it in the water, I slip the center part down in the other part until the top is flush, tighten the thumbscrew and my transducer is set the same every time.
Sure is a nice looking piece and some good thinking on your part! I like your idea. A Question for you! Looking at the design it appears you have only one thumb screw holding the adjustable sliding plate in position. Does that ever come loose after a days hard operation? Can you post some general dimensions and add anything you might change if you did it again. Thanks
One thumbscrew does fine. When it bottoms out, you can get a little "tweak" on it and it seems to seat OK. I have not had it come loose, but the cable is secured and if the thumbscrew were to back out, the transducer would only dron 1/4" or so, so it's no big deal. I attached the PDF drawing of the mount.
View attachment transducer mount.pdf
I've played around with trying to mount the transducer in the right place on both my jetboat, and on my 16 foot triton. On both boats, as soon as I come up on plane, it no longer reads depth. On my mom's boat, an 18 foot Sea hunt, you can run at almost full throttle before it quits reading. All 3 boats use the same fishfinder, a garmin 160C. So, why can't I get them to work on my aluminum boats? Does it have something to do with a metal hull vs. a fiberglass hull?
When I was talking to the salesman at BP he told me that the Gramins had issues with reading at speed. I would think that if it had anything to do with the difference between fiberglass & aluminum. Might have something to do with the shape of the hulls.
I had the issue with my Eagle loosing depth at speed and I finally got it working pretty well by remounting the transducer, it 15" from the prop and I placed it in between the ribs. I also mounted it on a1" cutting board so I could move it if need be. Before the remount if I lost depth I would have to come to a stop to regain it. Now I can slow down a little and it will normally come back.
Thanks, for the diagrams. Now my only problem is living where you can whizz in your yard :D . There are no machine shops nearby so I'll take a drive and see if I can find someone who machine that for me. Again Thanks!
I whizz in my yard all the time, and there are houses all around me. :mrgreen: Of course, my entire yard is bordered with trees, so, I have a natural privacy fence.
The guys's name who made it for me is Jerry Breedlove. His email address is [email protected] . The cost for the mount was $100 including shipping to me, which I thought was very reasonable. I checked at local machine shops and everybody wanted $150 or more plus tax.
Isn't that how you are suppose to water the grass? :?:
I know your post was directed toward PSG-1 but it sounds like something my wife used to say until she got used to me doing it...........Now she's jealous! :wink:
Not sure, but my theory is that there's no sense in wasting water to flush a toilet, when you can pee outside. :lol:
However, I would NOT recommend 'fertilizing' the front yard. LMAO
Well I went ahead and mounted my transducer the more traditional style for know. I couldn't find a anyone around here that could reproduce the bracket of B. Landry's in his drawing. I still hope to do that sooner or later.
Got out on the water and all is working fine on the FF but I do loose side imaging at almost any speed above 3-5 MPH. I'll figure that out later but my question is.........Do these things (transducers) usually leave such a rooster tail? When I operate on plane there is a rooster tail higher than the outboard coming from the transducer and faster = higher. Looks strange to me but may be normal. Was concerned that I might have it mounted too low in the water? The transducer is just below the bottom edge of the boat on the trailer but when loaded and in the water the boat is nearly half under water itself making the transducer even deeper. What are your thoughts and opinions?
I don't think the transducer should be making a rooster tail, I think it's to low in the water, if I'm not mistaken. For the most part the center line in the transducer should be even with the bottom of the boat and level with the water.
Mine doesn't rooster tail, WOT & 25 mph
I also had a rooster-tail problem and it was so bad it was spraying on the side of the motor. I even moved it to the other side thinking that maybe it was prop wash causing it. I finally raised it to where the bottom of th transducer was about 1/8" below the bottom of the boat and the problem went away. I still don't get a reading at high speed, but I think that takes a different style transducer.
what kind of FF do you have? ive never seen one that does not read at high speeds... and your ducer should be mounted about 1/8 inch below hull, so the water from ur hull runs smooth over the bottom of the ducer....
Gramps50, I never noticed the old transducer throwing a rooster tail either. This side imaging transducer is a lot larger than the old one (both hummingbirds). I was on a lake all last week and tried to look at everyone I could as they launched but was unable to find a aluminum boat with a side imaging transducer to compare. Might be a good reason to call their Customer Service???
It's a possibility I have it mounted a little low as you suggested!
The HB side imaging transducers take a lot of tweaking to the mount location and angle to be able to get decent 2D readings at speed, especially on tin boats with rivets, etc. I finally gave up on moving mine and just added a second, 2D-only, transducer, which when connected to the head unit with a "Y" cable, eliminates the 2D feed from the SI transducer. By doing that I was able to raise my SI transducer well above the bottom of the boat (to avoid it ever hitting anything) while still getting good 2D readings at speed.
Edit: Here's a pic of my setup...not the greatest angle for seeing the height, but the SI transducer (starboard) sits about 1/2 - 3/4" above the bottom of the boat, and the 2D sits below the boat. I could have set the SI much higher, but I was afraid the signal would bounce off the 2D transducer.
The rooster tail on some of the HB SI transducers comes from the design of the mount bracket having a hole/gap in it, and for some models there is an HB plug which fixes it. Some ppl have used silicone to close the gap, some have put a plate over the mount so the rooster tail is deflected, etc, etc.
There's a lot of information about SI transducer placement on the Humminbird Side Imaging Forum
Did you know that hull design, including aluminum (tin boats) assembled with rivets has nothng whatsoever to do with your external high speed or imaging transducer sounding? A row, or even a triple row (or more) of round rivets heads smattered across your transom have simply become an excuse for a poor resultant transducer sounding. A trailing transducer, adjusted flush with, or even below the bottom of any running surface, tucked up tightly to the transom, is forced to plow with stern down as the boat displaces water and moves at speed. The dynamics behind a fast moving boat are tremendous. We're taught to cause the transducer to plow below the running surface and is most often fatal. We must think about what actually occurs back there. The accompanying basic transducer bracket oftentimes fails us and will not permit the correct latitude of adjustment and location for an optimum sounding. Roostertails, garbled or grayed out screens, rubber plugs, silicone and electrical tape become the norm when ALL are all unnecessary. Unfortunately, we've been forced to resort to all manner of shade-tree "fixes" (often exacerbating the problems) and forum help from others. If your electrical is correct, including guage and run, and your electronics work properly at drift, a correctly installed external transducer will sound at optimum on any boat at any speed.
(June 24, 2012; New Starcraft Islander, new Humminbird installation, perfect marking all speeds , no roostertail...no installation damage)
