mmf
never use bronze or copper against an aluminum hull, will react and corrode!. Use NYLON thru the hull fittings. If you run a livewell pump with it's plastic (not nylon) tube thru the hull you take a chance of something sliding and hitting the pump and braking it off or just a freak accident, and you will take on water fast!. The nylon fittings will not dry rot like the plastic ones will either. Me, myself, will never one of those livewell pumps thru my hull, too many bad experiences.
