Douglasdzaster
- Joined
- Sep 19, 2020
- Messages
- 780
- Reaction score
- 462
- Location
- Smithville,Texas
- LOCATION
- Smithville, Texas
Hi everyone,
I took my boat out for the first time after I’ve been rebuilding it for a year. The trolling motor was stored in my shop. I thought I’d checked everything before leaving the house. I wiped the dust off the trolling motor and used a water base vinyl rubber and plastic treatment on the shaft so it would slide in the bracket and steer smooth. It’s a Min Kota 55# 12 volt that I reversed the head on and built an adapter for the bow and it was working great until it sit all this time. It’s on a 16/52 aluminum flat bottom. When I got to the lake I clamped it on the mount plugged it in and when I hit the button nothing. I could here it click in the head though so it was getting power there. Then I did something stupid. I still had my hand on the button and tapped the prop with the other hand and it took off. Nearly got my fingers.
I got out on the water and when I used it the motor didn’t feel like it was pulling as good as it used to. I thought I did have all my gear in it and the wife was with me this time. Ten mph wind. But I also know the new floor is lighter than the old one. Maybe my battery was trying to give it up. Later on I put it in reverse and it made a growling noise so I stoled that mess and put it back in forward and it ran smooth just didn’t seem as powerful. I stopped using it and pulled it out of the water and laid it down and locked it. I leaned out a little and found what I didn’t check. I saw grass. Dead grass so I know it’s been in there the whole time. I haven’t had a chance to pull the prop and clean it out and see if there’s fishing line or something else in it. I’ll do that this evening after it cools down a little outside. I got cooked on the lake yesterday by the Texas sun.
Once I clean it out is there anything else I can check or lubricate?
Oh,as soon as I got home yesterday I put the multimeter on the trolling battery and it had 12.5 left in it so as all was I put it on the smart charger to top it off. Battery had plenty of juice. Could that stuff sitting around the prop shaft for a year bound it up that bad?
