kingmontkid
- Joined
- Jan 29, 2012
- Messages
- 7
- Reaction score
- 0
Okay, i know there are plenty of posts on here about extending TM cables. But I didn't really see anything comparable to what I want to do on my Coleman Crawdad. Please hear me out and advise if what I'm thinking is possible. I'm an electrical beginner....so bear with me.
The whole idea behind this is I'd like to reduce/trade weight in the stern. I sit back there (205lbs) and typically have a TM, 5hp gas motor, and battery back in the stern with me. Lot of weight. I just got a new MK Endura 55lb transom mount to hopefully eliminate using my gas motor (weight and space on my transom) and gas can. The lake I fish at primarily is a short jaunt, less than half a mile from the ramp to my spots. So for the TM, of course the cables are like 4 feet. So as to not void it's warranty (and because I barely know what I'm doing), I'm leaving them alone.
I got 10 feet of 8 gauge wire. I just put on ring lugs on one end of them.....crimped them down with several smacks of a 3lb mini sledge. Nice and tight, no wiggle, I'm happy thus far. I'll put another set on the other end. I'd like to put my battery as far to the front/bow as possible. So I will connect these 8 gauge wires to the battery and wingnut them down. For the other end, I'll route them through 1/2 in PVC under my plywood floor.
Here's where I get a little confused with hooking the wires up to the TM. I do not want to do any splicing. So, can I create a "homemade" bus bar? Say a scrap piece of treated pine, run a 2 in" stainless 1/4" bolt up from the bottom, counter sink it. With the bolt protruding from the wood, add a few washers, then the battery leads, then my trolling motor leads, followed by a washer then wingnut it down?
Again, please, I know I may be doing it the hard way here and unnecessary, but I am uncomfortable with splicing wires from a $250 TM that's brand new. Especially since I have little experience with electrical work. Please do let me know your thoughts.
