Trolling Motor Quick Connect electrical
Got this one at West Marine. It twists and turns to connect/disconnect.
    156 KB
Those would work but I would get the MK brand ones that look very similar to that, are <$20 at WM and most other retailers, and work great, very durable as I've been using one set for over a year now, with no issues. Local WM's have 'em real close to the MK TM's and accessories they usually stock.
This is what I use & if you buy them at a hi-lo place there cheep.($10 pair or less)
I've had mine for years & no proplem
https://www.ebay.com/itm/SNOWBEAR-Snow-Plow-Winch-wiring-end-wire-plug-50-amp-Connector-quick-disconnect-/361122952899?pt=Other_Vehicle_Parts&hash=item54149af6c3&vxp=mtr#ht_530wt_1105
X2 on the Minn Kota at Walmart. Decent quality and you can have it TODAY. Only complaint is the cover for when you are not using the plug can detach easily during installation. You will need to provide the supply wires to the battery.
