CatfishJay1119
Thanks fishingmich the motor itself was well worth what I paid for the boat. I agree with you on the revving part its really the only downside for me.
I was doing some brainstorming tonight about the bow bracket and the two rear ones they have a handle design that I absolutely cant stand. Instead of using the brackets Im thinking of fabricating new brackets with aluminum angle and some aluminum sheet to give a flat surface for anything needed such as navigation lights. For the bow I'm thinking of doing the bracket the same way I also want a solid surface for the top for an eventual trolling motor and to make the board more rigid. Right now its far to light and floppy for my taste. (Yes floppy is a technical term
The other thing I'm thinking about is replacing the top aluminum lining with either aluminum angle or aluminum channel. The main reason for doing this is to make the boat more uniform if I decide to fabricate the brackets. If this is a good or bad idea let me know. I'm open for suggestions I want my boat to be as safe and structurally sound as possible, so anywhere I can beef it up I'll do it.
