sonny1
- Joined
- Feb 20, 2023
- Messages
- 589
- Reaction score
- 762
- Location
- Henryetta Oklahoma
- LOCATION
- Henryetta oklahoma
Reading up on this epoxy and it appears to be some good stuff. Is it worth the money? Anyone use the fiberglass tape and epoxy for fixing a crack in the hull? While wire brushing the boat I found a crack that appeared to have been repaired with fiberglass tape and some type of epoxy. Believe they used the West system epoxy. The batch was solid. My wife's brother used the boat a lot and know the patch was on for at least three years. Boat is being cleaned down to bare metal inside and out. Plan on using this product to seal all the riveted seams. The idea of using a propane torch to wet the epoxy into the seams sounds good but does that actually work? Feedback would be appreciated.
