What speed to use the trolling motor on?
basstender10.6
New Jersey
I have a minn kota maxxum 55 transom mount and a 50lb thrust endura. I never go full speed because once I did that and the wires got hot and the battery started to smoke near the terminals. I assumed it was because of a poor connection so I added O rings and have never had that problem. So, is it bad to run a trolling motor at full speed? If so for how long would be safe?
sounds like you could have had some dirty terminals, i wouldnt say its bad to run it at full throttle, just drains the battery.
you either had bad/dirty connections or the wire was not large enough for the amp draw being used when the smoke happened. You weren't running both TM's at the same time were you ?
Thanks. I was just running one digital maxxum 55 with original wires that it came with. I think there were 6 gauge.
On electric only lakes i run mine full throttle to get from spot to spot
I normally use three - a 55lb bow mount and 2 42lb transoms - each uses an independent battery
You should be able to run as fast as the motor can produce. If not you need to fix what is wrong to make the heat. Usually bad connection, or connections. Well assuming your trolling motor is OK and battery/batteries are well.
Oh my gosh, what size boat and what is your top speed?
16' "V" hull
Top speed on the trolling motors is almost 3.2 MPH
as long as you have the correct wire size and good connections you can run the motor at full speed without any problem
I run my 36 volt 109 lb thrust on high all the time never had an issue
unless you count almost going overboard when the motor is turned to a side and i step on the button
We would never count that :mrgreen:
:twisted: I run my 54lb MG bow motor and 54lb MG transom motor on high all the time. Never had an issue. Check all connections. Make sure you have the proper gauge wires.
+1
by the way ditchen love the profile sticker, i got to get some of these for work
I had a problem where the wiring IN the trolling motor burned through the insulation and shorted out. I was running on high for a long time- against the wind - in thick weeds when it happened. A few weeks ago I was trolling on 4 and 5 speed (against the wind). The battery was going slow so I decided to swap the troller and starter battery. The terminals on the battery were TOO HOT to touch. The terminal were all cleaned just a week before that trip.
The wiring is a gauge bigger than came with the trolling motor, straight to the battery - all of 6 feet.
That has happened to me because I run the standard wires that come with the motor right to the battery and often check to make sure the wing nuts are on tight, and lately it has been getting very hot.
