Where to get a prop?
acwd
Albion, IL
I got 1956 Johnson 15 hp. I need a prop. Its a 9 1/4x11. Does anyone know of a place that has them?
Thanks
Steve
Click on this link https://boatpropellers.iboats.com/Johnson-Outboard-Propellers/?chart=8&engine_id=28&cart_id=210043460
You should be able to get an original match off of https://www.marineengine.com/ or any other part you need unless its not available.
Thanks guys, I think I need a different prop. I made the old one work for test purposes. Seems slow and motor dont sound very high rpms. So now I need a tach and see what its turning. Its running right and good just seems like it has too much prop and not enough rpms. My 9.9 is faster then the 15. So now I guess you get a smaller pitched prop to raise the rpms?
Steve
Also remember depending on the year of the 9.9 the hp maybe an at the prop rating.
