well I got the aluminum plate under the platform and above it as well so the wood is just a filler, seems a bit more stable, tried pushing on the motor when it was deployed on the trailer, didn't feel like it would rip out but it does pull up a bit, the problem with the quick release bracket is that the puck is in the middle of the motor base so there's nothing holding the back portion of the motor base from lifting up, it's not a great design but I can't leave the motor on the boat 24/7 as someone already tried to steal my #55 endura c2 off the boat when I got it the first time last year, luckily having a very loud dog scares people away.
the issue I'm facing now is that the boat is still pulling driving at an angle, I have the motor mounted at the center line, it deploys dead center, but when I have it pointing forward trying to drive straight, the boat rides with the bow at 1 o'clock and the transom at 7 o'clock while moving towards 12 o'clock. I have the #55 endura c2 on the transom locked at 12 o'clock to act as a rudder as some of you have suggested but it's not working it seems. (also serves as an emergency motor if my bow one decides to rip off again, it was not fun paddling 100+ yards back to dock.)
is there anything else that could be causing this?
and for the suggestion of clamping a piece of metal to the transom to act as a rudder, does anyone have pictures of one they've made?
how far down off the bow should the motor be? I had it about 8 inches under the surface of the water but the boat didn't seem to be moving all that much faster than when I used to use just the #55 motor to drive the boat. I figured the #80 TM would be much more powerful and faster than the #55, was this a misconception? I know I added about 100lbs of aluminum and wood to the boat but it should still go faster should it not?
and finally, is there any bonus to running both the bow mount #80 terrova + the #55 endura at the same time? like have the 55 locked in the forward position at all times to propel the boat while the 80 pulls the boat and steers?
hoping to figure this all out as these problems have put a downer on how proud/excited I was about how good the boat looks after the decking modifications.
