Popeye
I'm gonna place an order with Blue Water LED for the 25 piece LED string. Mike says it is close to 12' long. My plan is to mount it UNDER the trailer frame starting from behind one wheel and going back to the last cross frame member and fwd to the other wheel. These are white LED's and I am planning on using them for backing up in the dark. My two options are wiring it to the backup light circuit so they light up when I put the truck in reverse, or... wiring them to the tail light circuit and installing a switch on the tongue so I can turn them on and off and that way they will be able to be on without having the truck in reverse. Like when the trailer is in the water on the ramp and I am trying to load the boat. Watcha think?
