CedarRiverScooter
- Joined
- Nov 13, 2014
- Messages
- 1,522
- Reaction score
- 6
Looks like great progress!
If your welds don't need to be waterproof, then making a bunch of short ones may be easier. I had the problem of heat getting head of me & I would burn a big hole after about 4 inches.
Regarding running the engine out of water, it behaves drastically different with no load, won't tell you much. I tested mine by tying boat to traiier extra well & running engine with trailer backed down ramp. Stirs up some mud but much safer than being out in the current.
I had problems with th 'pop-off' springs, made it run bad at midrange. There is a pressure test for pop off you might want to do.
Good luck.
Good luck.
