Bign0703
Anyone have a sharable link to a yamaha manual for a 2004 f50 4 stroke carb motor?
Bign0703 said:Anyone have a sharable link to a yamaha manual for a 2004 f50 4 stroke carb motor?
turbotodd said:The jetting is staggered too. As I remember, pilot and main jets differ between cylinders. Also the prime start system only primes two of the four carbs. The passages in the bowls for the prime start tend to plug up, and they are no fun to get clean. If they aren't squeaky clean it'll be hard to start and it won't idle properly even when hot. Yamaha put out a bulletin for the F40 (3 carb/3 cyl and the 4 cyl/4 carb) and F50X that addressed the cleaning procedure, but they also suggested to replace the bowls on the prime start carbs rather than cleaning them.
gotta use a manometer to sync them too, along with the correct adapters for the intakes. And people wonder why they cost so much to do the job. I wouldn't do them for less than 3 hours labor. Most of the time it was a little closer to 4 hr by the time they were properly cleaned, sync'd and then test run.
Pappy said:You realize you need a carburetor sync tool to get them set up correctly after cleaning. You can have the cleanest carburetors in the neighborhood and the engine will never run correctly if the throttle blades are not set correctly.
Bign0703 said:Pappy said:You realize you need a carburetor sync tool to get them set up correctly after cleaning. You can have the cleanest carburetors in the neighborhood and the engine will never run correctly if the throttle blades are not set correctly.
Yes sir pappy. Thankfully mine are broken! I haven't used them in years so after the move I guess I can't be too horribly mad. They were a cheap set I bought about 15 years ago. But new set on the way and she will hopefully be ready to go by the weekend
Pappy said:Bign0703 said:Pappy said:You realize you need a carburetor sync tool to get them set up correctly after cleaning. You can have the cleanest carburetors in the neighborhood and the engine will never run correctly if the throttle blades are not set correctly.
You must have been around the motorcycle world for a while then.........!
turbotodd said:Double and triple check your part numbers & sizes for the jets, and make sure you have them in the right places.
yes, a motorcycle style manometer for carb sync is almost a requirement, as are the correct adapters that screw into the intake manifolds. It can be done without, but with, it idles even better. The F40/F50 4 cylinder motors are silky smooth-when set up right, at idle they are absolutely silent with the cowling on.
Speaking of cowling. A very common issue IS the cowling. I've seen more than one that had the air passages restricted by dirt dobber nests or whatever. Take the cowling off, flip it over, and remove the screws that hold the baffles on. See what you can find in it. I certainly hope that is where your issue lies. I pity the poor soul that has to do carb cleanings on these F40/F50 4 cyl motors. Worst set of carbs I've ever done in my 40 some years. So when you get it figured out, I'd highly suggest running ringfree plus fuel additive or at the least a good stabilizer, and start the motor about once a week to keep fuel circulated when you aren't using it. Makes a big difference. Maybe you won't have to clean the carbs again.
turbotodd said:I dug my old 25 2 stroke (3 cyl) out a while back and tossed it on, run it around the lake a little, and as soon as I got back home I pulled it off and put the 4 stroke back on. I forgot how crude that old thing is! Pickled and back in storage for another year; unless I decide I have to sell it for whatever reason.
wmk0002 said:turbotodd said:I dug my old 25 2 stroke (3 cyl) out a while back and tossed it on, run it around the lake a little, and as soon as I got back home I pulled it off and put the 4 stroke back on. I forgot how crude that old thing is! Pickled and back in storage for another year; unless I decide I have to sell it for whatever reason.
Hit me up you ever want to sell it!
turbotodd said:wmk0002 said:turbotodd said:I dug my old 25 2 stroke (3 cyl) out a while back and tossed it on, run it around the lake a little, and as soon as I got back home I pulled it off and put the 4 stroke back on. I forgot how crude that old thing is! Pickled and back in storage for another year; unless I decide I have to sell it for whatever reason.
i put you on the list.
