Yamaha 15 HP electric start not starting!
Does this outboard have an ignition switch?
Would need to see a wiring diagram to be sure, those start systems are pretty simple. Power usually comes from the main fuse, to the ignition switch, to the start switch, neutral safety switch, and finally to the starter solenoid. Since you have eliminated the solenoid and the neutral switch, my guess is that you're losing power somewhere between the fuse and ignition switch, perhaps between the ignition and the neutral switch.
You can quickly test the integrity of the starter motor, solenoid, and battery by just jumpering the solenoid. Rig up a test lead from battery positive (where the battery positive cable attaches to the solenoid is just fine), unhook the positive coil wire on the solenoid and apply power to it, the starter should engage. If not, you have a poor connection somewhere or bad solenoid.
If it does crank, get a test light or voltmeter and follow that positive solenoid coil wire backwards until you find power again. This is best done with a wiring diagram to "light your way," so to speak.
I'm going to start this right now. Stay tuned!
Just to be sure, swap out the fuse with a fresh one, and make sure the socket is clean. This will fix these issues occasionally. A partially burned fuse or poor connection may show 12V on a multimeter, but cannot carry enough power to do trip the solenoid.
How did you jump the solenoid? Did you jump across the main lugs, or did you jump 12V directly to the trigger wire or stud? This matters. Here is the sequence I usually follow:
  1. Use a wire connected directly to 12v and touch it to the small start wire or stud of the solenoid. It should turn over if the solenoid is good and connected properly.
  2. If it DOES turn over, the issue is somewhere in the start button circuit, and easy to find. Fuse, frayed wire, bad connector, etc. It's there somewhere.
  3. If it DOES NOT turn over, then check the ground wire of the solenoid.
  4. Sometimes, a solenoid will be replaced with the ground connected to the wrong stud, and the solenoid won't work. Double-check the wiring
I hope this is helpful. You WILL find it, probably soon if not already.
I jumped the solenoid by connecting the battery directly to the starter motor ground and the positive wire leaving the solenoid.
Can I ask what you mean by 'wrong stud?' I broke the head off the original stud when I was reassembling it earlier so I've been using a different one. In another forum chat I was advised that this was ok to use so I thought this wasn't the issue. NOTE: These problems happened before I relocated the solenoid ground to this new stud location
    126.5 KB
    130.2 KB
What do you think about moving the ground to this location (since the stud original stud location is broken)
Ok something definitely with the solenoid, since I'm able to jump it with your instructions. I replaced the solenoid already but maybe the grounds are not in the right spot (I had to relocate due to a broken bolt)
That sounds more like you just jumpered the starter motor. You need to unplug the small trigger wire on the solenoid (likely has a bullet connector) and apply +12v to it. The other small wire will need to be grounded to the engine block, the pictured bolt would be fine as it seems there are several other grounds already terminated there.
The posted diagram does not appear to be correct, pictures of the starter relay would help us give you some direction.
That missing ground for the solenoid would certainly cause the no-start condition.
If you can't extract the broken bolt threads, moving the ground wire to a good ground bolt is the right move.
You didn't jump the solenoid, you bypassed it completely. At least you are getting closer to solving the mystery.
Mystery solved!
Well after about 2 weeks of paddling I have finally fixed the problem. Thank you to everyone, I learned so much more about my outboard. Before this I didn't really understand the working of my outboard or what a lot of the major components did. Though this was unpleasant I am actually kind of happy it happened, I now can be more self-sufficient in helping not only myself but other boaters.
So what was it?
I store my starter battery in the bow, to keep it away from the fuel tank. When the boat was originally purchased the battery cable was too short, so I had a 'professional' extend it. He used heatshrink and extended the 10 AWG wire to feed the battery. While working through this current situation I really pulled on the area where the battery feed wire was extended. I head a pop and was greeted by the most corrosion I have ever seen (picture below).
Why didn't I do this before?
When I was diagnosing everything, I was checking voltage and I was getting a good voltage! Though I have been constantly warned about corrosion I didn't think there would be any in connection point of the wire. Looking back this was a super easy solution (and no cost because I have plenty of heat shrink terminals). In my mind, there was no issue with power at the solenoid, starter or anywhere because I was reading 13V. Though I had proper voltage, I didn't have enough amperage to open the solenoid.
Am I upset?
A few days ago, very. I didn't understand how something so new could be so unreliable. Now I know that it wasn't the outboard at all but rather the wire feeding power to the outboard. I've learned so much though that the 2 weeks of me paddling back and forth to shore will soon be forgotten and I get the biggest smile everytime my outboard fires up with a simple push.
Time to dinghy to shore and start the weekend celebrations early.
Cheers everyone!
P.S. the wire is so watertight and well connected now that I'm not concerned about corrosion in the future. But if it does happen, I'll know exactly what to do.
Mystery solved!
So what was it?
Am I upset?
Cheers everyone!
Signs of a good mechanic perseverance, reaching out for good advice and stay at till fixed. In the future because of your experience you will find your troubleshooting is more orderly and easier.
