Your auction scores!
GTS225 said:
JMichael; Before you modify that stock, check with the company in the link below. They may be able to fix you up with a "spare" stock that you could modify. That way, you can switch out stocks as needed.
https://www.gunpartscorp.com/
Roger
I considered that option and ruled it out mainly because the total investment to go that route. Stocks start around 125-150 and go up from there. Add the cost of a top notch recoil pad + having it fitted to the new stock and that's going to drive the cost up close to what the guns value is going to be. And then you've got the very likely possibility that the stock and fore end are not going to match (stain wise) so it's going to look bad as well.
