1999 Carolina Skiff J-14 Mods
- 14
I recently sold my 1988 Alumacraft and purchased a wider, fiberglass jon boat. I wanted something more stable as the Alumacraft was pretty tippy and I had a nice scare when we got stuck on a hidden tree top. Water almost rushed and and only thought in my mind was a new 4 stroke motor going 15 feet into the drink. After that day, I did not use that boat anymore and it sat for a year in a friends garage ( although he had permission to use it and he didnt ). One day in late March 2012, I came across a Carolina Skiff on Craigslist that was about an hour away for $1300. Knowing that I had always wanted a Skiff, I had kept this one in the back of my mind. I figured by the time I got the funds, it would have already been snagged as these boats are pretty sought after in this area for the smaller lakes. I called the number in the listing and sure enough, he still had it! I went and got it that Saturday and didnt even haggle on price or really look it over that much.
When I got it home, it was really nasty, and I can tell it had been sitting for a long time, even though there was a tarp over it, didnt seem to help much. It was parked under a tree and just debris was everywhere in the smallest of areas in the hull.
Issues that have been corrected and Mods:
Big chip in the fiberglass chine: Patched, Sanded down smooth and shot with white Krylon spraypaint and clear coat ( matches great )
Various other small chips: Filled with JB weld, sanded smooth and shot with white paint ( did a great job with JB weld! )
Cleaned the hull with stuff called "Awesome" from Dollar General ( only $1 a bottle ) did wonders and shined it up!
Scrubbed the nasty old leaf debris and dirt out of the floor with a wire brush and cleaner
Removed an old trolling motor bracket and filled the holes with JB weld and sanded down
Fixed a big hole in the deck where a depth finder was located, with fiberglass repair kit, sanded and painted
Installed a new red/green light on the front
Installed a new rear light socket with new LED light for night saftey
Cleaned the storage box the best I could and sprayed it with white krylon and clearcoat ( it was nasty!)
Ripped out ALL of the wiring
Ran wires from the back to the front ( through a pvc pipe attatched to the floor)for TM, Fish finder, Light, 12volt outlet and a spare
Remounted the switch panel
Added a master on/off with removable key, in the rear bench, behind the seat, on the lip
Added a 12volt aux outlet in the rear bench, behind seat, on the lip
Installed a Eagle ( made by Lowrance ) Depth Finder on edge of bench so it can be seen with running
Installed a Garmin 140 on the front deck
Installed a New MinnKota 45lb 12V TM with foot control
New Deep Cycle group 29 battery
New gold positive battery terminal with power distribution block
New front seat post mount
New front seat pole and butt seat
New bilgepump
All wired to the power panel switches
Under the deck by the access holes, i put in a truck bed net to keep the life jackets from coming out.
Installed new Battery box
New 3.5gallon fuel tank
Trailer:
Tongue of trailer was really long: Cut of 24inches of tubing, put on new 2 inch coupler
Trailer wiring: Replaced the wiring and 2 side lights
New Tires on trailer
Rubber no slip grippers put on fenders and tongue
New trailer jack wheel
New Trailer wench and strap
New bilgepump
Trailer:
Alumacraft Build
https://www.tinboats.net/forum/viewtopic.php?f=3&t=8876
Carolina Skiff J14 Mods
https://www.tinboats.net/forum/viewtopi ... 21&t=27593
My fishing Rigs:
2009 Yukon Denali XL
2004 Ranger 519VX Comanche Ranger Cup
2004 Mercury EFI 200HP
2009 Tohatsu 9.8hp / electric start/ shortshaft
My fishing Rigs:
- 14
The day I brought it home. Sitting in the parking lot of the DMV
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
- 14
I put it on a friends driveway since there was alot of room to work and not in anyone's way. It had rained so much, it was hard to get anything done for a few weeks.
Here is one of the many times it was full of water and I had to pump it out with an old bilge pump and half dead battery. This was not much water compared to other days. Some days water was half way up the front under the deck.
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
- 14
Cutting down the trailer tongue as it was WAY too long. The trailer is a SmokerCraft Tennessee trailer and did not originally come with this boat.
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
- 14
New 2 inch coupler, new jack wheel ( old one not removed yet) and ready for a rewire.
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
- 14
Some fiberglass repair. I have never done this before and bought a kit from Walmart. It was really simple to patch, wait an hour or so while I did something else to the boat, then sand her smooth and paint.
There were several places I had to pull in, like knicks and chips and used JB Weld on the small areas. Which worked like a charm. I then shot Krylon White spray paint and a clear coat over it.
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
Good looking rig, what are your plans to put on the back?
I had a J16, lots of water in the floor.
- 14
Cleaned out the storage box, it was the battery box and I dont know why the other owner had it on the side instead of in the back of the boat near the panel. I removed the box, hosed it, scrubbed it, then said to heck with it and painted it white and clear coat. Bolted it back in and siliconed the bottom and the screw holes. I also filled in some holes in the bottom of the bench that was used for wire pass throughs, used JB weld
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
- 14
I have a Tohatsu 9.8hp 4stroke.. only goes 7mph though and wont plane. I may have water in the floor.. how do i get it out?sixgun86 wrote:Good looking rig, what are your plans to put on the back?
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
- 14
Drilling the front deck for the seat post mount. Smoked my cheap drill!
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
- 14
Front fish finder mount installed. I ran all wires under the deck at a later time, so there is less trippage.. Installed a 12volt plug for night time headlamps.. which worked great the other night
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
- 14
New Trolling motor from Bass Pro Shops
MinnKota ( only the best) 12volt 45lb
This thing will scoot that skiff pretty good on #3 setting, and seems like a rocket on #5
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
- 14
Another view of the trolling motor mounted to the deck. This was really hard to get the nuts through to the under side as we didnt take the deck off to mount the TM. My friend had to lay in the boat, hold the nut and washer on a crescent wrench with a dap of silicone for it to stay and the wrench was attached to a metal pole so it would reach. I screwed from the top with my drill and after the 3rd bolt, it was super easy. We had it mounted in 15 minutes.
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
- 14
Ready for a test run...You can see the rear depth finder bracket on the bench edge. We strapped the motor down because it wanted to bounce. For some reason the motor wouldnt lock down.
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
- 14
My buddy, firing up the motor for the 1st time since late 2010. She ran like a top.
Alumacraft Build
My fishing Rigs:
My fishing Rigs:
