Baptistpreach's 1436 Monark -100% 8/14
baptistpreach
Post by baptistpreach »
I'm following pretty closely to what member PBW did with his, and when I'm done its gonna be quite a catfish and crappie rig. (of course I fish for bass too!) Anyhow, here's what it looked like when it started!
And this is what it looks like finished (minus the lettering which can be seen on the last page)
Living proof that anyone can, if they just try.
If you don't see me here, I might just be out on Visitation!
pbw
My First Jon Boat Mod!
Post by pbw »
Good Luck..... Nice looking clean rig to start from..
PBW
russ010
Post by russ010 »
looks like you should be able to make you a pretty nice boat.. can't wait to see the end result
I like it as is! If it was mine I would just put a nice level floor to walk easier on.
Free Decal? Click here to get one!
dedawg1149
Post by dedawg1149 »
nice boat i would fish it as it is
The fishing was good,it was the catching that was bad
Cheeseball
Post by Cheeseball »
Nice rig to start out with. Is the front port side dented or is that just an illusion of the camera angle?
baptistpreach
Yes, its dented, I guess his son in law did that accidentally, but it has no leaks and I couldnt beat the price $250 for the boat, trailer, and a trolling motor!
btw, Thanks for the compliments, but I was hoping for some more encouragement to mod it! I'm too far committed to stop now!
Post by Waterwings »
Nice rig! 8)
baptistpreach
First thing I did was coat most of the inside with spray on bedliner. Why you might ask? Well, because I heard it might help keep the boat sealed (probably not), it gives good grip, and because I think it looks cool! I also included some pics of what the floor looked like before. I washed the boat out at the car wash and let it dry before I did any of the spraying. While the true practicality of the bed liner may be in question, it did wonders for the appearance of my boat!
baptistpreach
Then I started to build my supporting frame for the front deck. I've never worked with wood before, so this was definitely a learning experience, but I'm really liking it!
ben2go
Post by ben2go »
Looks good.Did you fix the punched nose?A hammer and a 6 inch long piece of 2x4 will fix it.
ilinimud
Post by ilinimud »
Its looking good, keep up the good work on it.
"Come ye after me, and i will make you become fishers of men..."
-Jesus
baptistpreach
Here's the pics of the current state of the boat. I unscrewed everything that had screws (not really very much) and water proofed all the wood 3 or 4 times. I then went back and secured every thing firmly, added the three horizontal cross supports and one more middle vertical support. Every support has four screws, everything is level, and next I will cut my deck for the front and take it out for a water stability test to determine where I'm going to mount my front seat, which will then determine how I do my storage. I've also included a picture of the rough idea for my rear deck with the storage / livewell added. I want to see how the boat will run with that much water weight in it. If it can work though, it will be a HUGE livewell!
P.S. the tool that is laying on picture 22 is a 90 deg. tool that was very valuable to drill my supports in on some tight areas!
Zum
Post by Zum »
Your boat is looking good.
Other then a square never heard of a 90 degree tool.
I see another boat in the background,looks to be fiberglass with side console?
baptistpreach
Yes, its a fiberglass with a 50hp motor, I'm doing my best to sell it though! After I sell it, I'm gonna be looking for a 9.9 or another decent sized motor to put on my jon!
