What kind of wood should I use use for my transom?
lswoody
Post by lswoody »
Got a 14’ Jon boat that needs the wood for the transom replaced. I know not to use any treated wood, so what options do I have? Thanks!!!!
Weldorthemagnificent
3
Post by Weldorthemagnificent »
I usually laminate (glue) 2 pieces of plywood together and then seal it with spar urethane. Some guys like the old timers formula of mineral spirits, linseed oil and spar urethane.
CedarRiverScooter
5
Post by CedarRiverScooter »
Exterior grade ply is OK, IMO.
Marine ply is not needed.
I have heard glue is the same on both.
MrGiggles
2
Post by MrGiggles »
If it had ply, replace it with ply. You may need to laminate a couple different pieces together to reach the correct thickness.
My alumacraft had a hardwood plank in the transom, so I replaced it with a piece of oak, planed to the right thickness.
