rhino jet jon
- 8
rhino jet jon
Went to home depot they carry behr paint products I bought two gallons of the deckover textured and had it colored sand stone bought a quart of glidden primer , dont buy the restore brand it is sand based and gets really hot the behr product is acrylic based and does well in the sun on a 90 degree day I kept my shoes off will post pics soon and also had to buy the special roller all cost me a little over a hundred bucks
- 8
rhino jet jon
Here is the inside completed
- 8
rhino jet jon
Here is what I did on the back to protect the nozzle and reverse, I made the trim tabs to stop the high speed pourposing , still pourposes but its not as bad, will have to figure that one out still
rhino jet jon
Are you using an OEM ride plate, or did you fabricate one?
Reason I ask is because I'm using a ride plate fabbed from 1/4" aluminum plate, and to combat porpoising, I bent a very slight downward angle on the last 2 inches of the plate.
With an OEM ride plate, you could still weld a tab on the back end, at a downward angle, and it would have the same effect.
ALUMA-JET project:
https://www.tinboats.net/forum/viewtopi ... 21&t=22023
Fishing, jet skiing, target shooting, jet-boating, and even a little oyster harvesting with Larry The Cable Guy.
Watch it all right here:
https://www.youtube.com/user/HKPSG1Shooter?feature=mhee
- 8
rhino jet jon
I trashed the ride plate there was no way it would work I welded .0125 aluminum behind pumpthen welded the cover to that. I have thought about welding another piece of aluminum on the front leading edge and fabricate two adjusters in the back on each side of the nozzle to make an adjustable ride plate
- 8
rhino jet jon
I do have a 2 inch slight bend on the trim tabs wonder if I should bend them more
- Moderator
rhino jet jon
I'd bend them more until you find the sweet spot. Just be aware that they are going to highly stressed and will break off unless you support the aft end.
My Seadoo Powered Bass Boat https://www.tinboats.net/forum/viewtopi ... =21&t=8385
YouTube channel https://www.youtube.com/user/ranchero50
- 8
rhino jet jon
i took out the boat recently messed with the trim tabs the boat didnt perform any better im thinking about redesinging the back end some kind of adjustable rideplate pod extensions right now they extend like 9 inches from the back and are unsupported im thinking at least 12 inches. i dont know but i think extending the back of the boat would make it ride better
- Moderator
rhino jet jon
You should be able to duct tape some plywood on the top of your existing tabs to see if the longer version is better. My hull with the pods planes smoother and flatter.
- 8
rhino jet jon
well I went ahead and removed the tabs on the back of the boat and traced the underside of the jet pump cover transfered it to a .190 piece of aluminum cut it out and mounted it on the underside of the housing and used stainless washers to shim it on the back side 1/2 inch took it out yesterday, its a totally different boat . wish id done this sooner will post pics soon
- 8
rhino jet jon
ride plate
- 8
rhino jet jon
a nice pic of it sitting in the river
- Moderator
rhino jet jon
Cool, that's similar to the tabs I mounted under my pods. Mine worked best when the rear was raised up flush with the pods.
- 8
rhino jet jon
Well , a month ago my engine gave out the rear cylinder gave out the piston had a burnt hole in it , my engine is running lean. I rebuilt the engine I have the largest jet you can put in carb which is in a mikuni 46 mm . The carb can supply fuel to up to a 800 cc engine with no problems, ive rebuilt the carb . Anyways Ive taken the boat out and it runs great but the engine is still running lean ive backed out the high needle another 2 turns and the low one more turn which is like , high 4 turns out and low 3 turns out how far can I back out these screws. Im thinking that changing to a dual carb setup would be an option, I dont know , help any ideas.
- 7
rhino jet jon
Sorry to hear of the burnt piston.
Is the fuel pump keeping up? Maybe a clogged filter? Is the pop-off pressure OK?
