thill
Also, depending on your boat, I typically like to use longer bunks and have THREE brackets per bunk. Or, I will add a second pair of bunks close together in the center to catch the keel of the boat.
Bunks are kind of fun to play with. I love it when a trailer really fits a boat like a glove. Makes loading SO much easier, and protects the boat.
Even if you just slap two bunks in, it should give better support than the rollers, with weight spread out more evenly under the hull.
