14 ft Smokercraft v-hull Project (COMPLETED-TONS OF PICS!)
The paint is drying. I used rustoleum rattle cans. Came out really nice!
    51.1 KB
Here is the paint after it has been dried
    119.6 KB
    165.3 KB
I cut out the two front bench seats and began framing off the bottom of the boat. I am trying to make a lower profile deck to help with stability.
    166.8 KB
I began re-structuring the boat for stability. After removing the middle and rear benches, it stability of the boat did worry me some. Became much less structurally sound. So I ran a 2x4 down the side, and tied them into the pre-existing brackets that held the benches. I then screwed the back of the 2x4 into the read bench seat which created a much more rigid and stable boat. I also traced out my bow deck so I can mount my bow mounted trolling motor up there. Up there is THE only place where I screwed into the boat but it is above the water line and I did not screw all the way through the void in the rim but just through the first layer so the screws would catch.
    193 KB
    150.7 KB
    158.9 KB
    184.2 KB
I finally finished the deck flooring, I had my dad help me so we could fit a whole 8' sheet of plywood in. I then coated all the lumber with Hellsman Spar Urethane to make it water resistant. I also mocked up where I wanted my seat bases to be, and to make sure to properly plan for them with the right framing.
    136.7 KB
    150.5 KB
    213.6 KB
    158.5 KB
I began carpeting all the plywood after the Spar Urethane fully dried.
    193.2 KB
    184.5 KB
Here will be the mounting deck for the bow mounted trolling motor.
    195.1 KB
I drilled a hole in the deck for the seat bases and installed the fishing seats that I got from Bass Pro.
    192.2 KB
    150.5 KB
Next I bought the battery and did the wiring for it, went from the trolling motor outlet to the 50 amp breaker, to the battery. Then I mounted my trolling motor bracket and Hull numbers!! Finishing touches! Hard work pays off!!!
    184.7 KB
starboard and port side view of the finished product!
    186.2 KB
    201.2 KB
A lot of time, hard work, and cash. But totally worth it. I am really looking forward to using it all summer long!
Here are some pictures of both motors on the water and a good side by side comparison picture of my transformation.
    234.6 KB
    161 KB
    186.5 KB
    88.8 KB
thewalleyehunter said:
Nice and simple....I like it! =D>
Ya I wanted to do a bit more with storage and such, but after thinking it over. I don't take a lot with me in the first place, so I just felt this was the best path.
jvanhees said:
good looking boat!
Thank You!!! Well worth the time and effort put into it. It has been a lot of fun thus far. Just need water temps. to raise a little bit and maybe we can actually catch some fish! [-o<
The previous owner saw the boat, asked if he could buy it back! hahaha!!! :LOL2:
I said no way!!! [-X
