Thought that boat looked familiar...
For the sawzall, get a 10-12" 18 tooth or finer blade, install it upside down and cut at a very flat angle. With the sawzall upside down it can cut at a much flatter angle. Ideally you want 2-3 teeth in the cut or it'll buck and jump and make you miserable. You can use some WD-40 as cutting fluid, it works great for aluminum.
With the circular saw set the blade depth to around 1/4" and clamp a guide board for the correct offset from the blade so you don't have to hover over the blade (cut aluminum is hot). Wear ear plugs, it's really loud. Put the aluminum on a sacrificial board (keeps everything from chattering and is much safer), I use old pallets.
If you want some help with it, let me know.
Jamie
