1448 Gregor brought back to life
evansjoem
gutting the pig
Forming a front deck
then the rear deck
Got some sealer to waterproof the deck
Just buttoning it up
Will adding more foam help me draft shallower
Tig welded float pots on
with a home built mud motor
Any suggestions??? I hate the exposed hinges. Maybe get piano hinges and hide them
It is an old 1448 Gregor. I am currently getting 12mph I think it's a 9.9hp can I go bigger
And it starts first pull great motor! ( worn prop) though I have a two blade and a three blade, both are used
You certainly can go bigger. My 12 ft. Gregor was rated at 15 hp (1979), but i found my 9.9 was plenty. If there is still a data plate on the transom, it might have the max hp rating.
