You did not clean the aluminum enough. You have to go down to bare aluminum, wipe with acetone and RIGHT AWAY prime it with Gator Base then go on with the G2 or G4.Abraham said:I had the same problem with pictures not posting because of the size. Just keep hitting submit and they'll take. Pretty aggravating after a while lol.
Was the boat still dirty when you applied the gator glide? The way the paint is fish eyeing makes it look like the surface is greasy or oily. Looks great other than that. I'm also considering gator glide for the bottom of mine but not if it's going to be a hassle.
[url=https://www.tinboats.net/forum/viewtopic.php?p=355135#p355135 said:smackdaddy53 » 08 Jun 2014, 18:31[/url]"]Our boats are similar sizes and mine took 4 gallons plus a gallon of primer. Did you speak with the owner David Ward? He is a straight shooter and gaurantee he would not have claimed a quart would cover that much surface area. You have to account for the ribs and going up the sides too. You can still add coats now, light sand it, wipe with acetone and roll more on.
[url=https://www.tinboats.net/forum/viewtopic.php?p=355118#p355118 said:Abraham » 08 Jun 2014, 17:10[/url]"]I had the same problem with pictures not posting because of the size. Just keep hitting submit and they'll take. Pretty aggravating after a while lol.
I am not accusing you of anything BUT I can see in your photos as you are masking it off that there is still original paint on the hull. That paint holds impurities. Look at how my hull looks, not a single speck of paint on that hull, just bare aluminum.bigredxlt said:[url=https://www.tinboats.net/forum/viewtopic.php?p=355135#p355135 said:smackdaddy53 » 08 Jun 2014, 18:31[/url]"]Our boats are similar sizes and mine took 4 gallons plus a gallon of primer. Did you speak with the owner David Ward? He is a straight shooter and gaurantee he would not have claimed a quart would cover that much surface area. You have to account for the ribs and going up the sides too. You can still add coats now, light sand it, wipe with acetone and roll more on.
I emailed him right before posting the pictures and he has already emailed me back and called. I will be returning his call tomorrow. I can guarantee that I was told a quart would cover because I have the email. I was also told gator base was a good idea for added durabilty but not absolutely necessary. So I can assure you I am not lying. I can honestly say its a great product and it has worked out great for other people, but for some reason it didn't work for me.
I not only wire brushed the entire taped off area, but I sanded it with 120 grit thoroughly. Then I wiped the entire taped off area thoroughly with acetone and started painting it within 5 minutes. Like I said I followed the directions word by word.
