I’ve had this boat for some time now and have finally decided to start the build process. It may be a slow build because I am only doing it in my spare time. I will be adding a floor, rod lockers, live well, front casting deck and of course storage. It will be 100% aluminum with possible exception of the transom. I’m not quite sure about that yet. I will be removing just enough of the middle seat to give an open floor plan. All the wood is removed already an I have started framing the floor with 2x2x1/8 angle. I will be using 1/8” plate for the floor and decking and putting some kind of kiwi grip or truck bed liner on it. I would like to make an aluminum transom but have some concerns with vibration from the motor. I have read where the wood transom helps to dampen some of the motor vibrations. The old transom was 2" thick. You can see the pocket that it was sitting in. Real easy to remove and install the transom board. The way the pocket is desined for the transom, it had the wood exposed on the inside of the boat and it is super easy to replace if needed so I may just stick with a wood transom for simplicity sake. I was thinking maybe go with a 2 ply of 3/4" marine plywood and skin it with 1/4" aluminum on each side to give me the 2", then just drop it in the pocket and fasten in place. I would appreciate some advice and ideas on this. The old transom was in pretty good shape but I thought for the price of a new sheet of marine plywood I would replace it. I look forward to any suggestions and ideas any of you might have.
B5D885D0-5F32-492A-82B2-E32CBED2A5ED.jpeg2 MB
94E476EA-1885-47FF-8E63-3FFAFD2BFF8C.jpeg2 MB
1E5811F6-BED7-4DF7-8973-84A978E277CE.jpeg2.5 MB
FCCC311E-5DE2-4934-8A14-85923D5CDFD7.jpeg2.5 MB
AAEB16D8-5C55-45F4-9D62-433C43AB3633.jpeg1.9 MB
923C6D74-094C-4734-942F-ED19F5707F69.jpeg2.1 MB
27686EC9-85DD-4B47-9447-3D0AA565F058.jpeg2.1 MB
