- Joined
- Jul 3, 2022
- Messages
- 863
- Reaction score
- 1,803
- LOCATION
- USA
Excellent! That is the same stuff i am using. I also had the thought of gluing a 2-3" block to the bottom part of the foam to elevate it up off of the floor as well.I used Owens Corning Foamular polystyrene 2" thick foam board insulation, the pink stuff. It cuts very easy with a sharp razor blade, I marked and cut each side which was deep enough to snap each piece apart. Any shaping was done with the razor blade as well. A saw would have just made a big mess. No glue needed for my boat as each seat holds 5 sheet perfectly tight. Note I did leave about a 3" gap off the bottom which will keep the insulation from sitting in water and also allow water to run under each bench seat.
While I am sure other insulation would work I read that polystyrene should hold up over time both to water/ice and also wont break down and leave little white beads all over the boat.
Thank you!
