So...Finally! It's done! Well, almost... this was the maiden test voyage. to make sure all electronics worked, all the live well plumbing worked, and that it floated. This pic was shot after the maiden run, waiting at the ramp to pic it up. My wife's son standing in the shallows with her while I back up the truck.
What went right:
What went wrong:
Okay so the maiden voyage consisted of staying pretty much in this cove off the main lake. A couple were trying out their new jet ski and flipped it over. They righted it, went to shore across from the ramp and couldn't back off the sand edge with both aboard. We picked up the one who remained behind and delivered her to the ramp.
What get's fixed: the bow ring (taking this to a welder). And a new gas can.
I had some problems with the original tank leaking air and couldn't get the motor to keep siphoning gas from tank due to an air leak around the hose inlet to the tank... once the air leak sealed, it kept running for at least an hour tooling around this cove and a little bit into the main lake. After it's all done, more pix of the interior and a few more details... this has been a long process... but finally, Ransomed has had her maiden voyage!
What went right:
- Seats. posts move from mid to front on the water without too much difficulty.
- Live well works, aerates on timer, drains as it should (on the trailer)
- No plumbing leaks
- All electronics work: battery switch, trolling motor, nav and anchor lights, search light.
- It works as a rescue vehicle (see note below)
What went wrong:
- Nothing until we got help from strangers who cranked it onto the trailer so hard they ripped open the factory landing ring on front of boat! We had to limp home carefully, with the winch strap hooked around the motor to transom mount to keep from losing the boat off the trailer, even with a back strap holding her on the trailer.
