flintcreek
You have made some head way since I have last looked.....keep up the good work...looking forward to seeing it finished....Flintcreek
Codeman said:I do have a question, what is the best way to determine how deep to set the trolling motor? This measurement will dictate where the base will mount.
russ010 said:I have yet to find the "best" measurement for how deep the trolling motor should be, but I have mine exactly where you have your (I have the blades just under the flat part of the boat) and that seems to give me the best performance so far... I've tried it all the way up just under the water, and about every place inbetween all the way down... I think you've got it bout right.
Man I agree totally. Just you....the sky....a motor that won't crank for anything...Codeman said:Thanks Brine, can't beat being on the water at sunset, stress just kind of melts away. I'm very happy with the way the mount turned out.
Codeman said:Been kind of lazy this week. Need to get busy and finish this thing! :?
Codeman said:My plan is to put my switch panel in this corner the colored in area is the actual size of the hole.
