1977 johnson 35 hp tiller pull start motor
Has a rough time starting hot or cold i have been looking for info and came up with
1 worn or miss adjusted carb float
2 carb needs cleaned and/or rebuilt
3 loss of fuel pressure
(i have read you need only to pump primmer bulb for the first start of the day and it shouldnt need to be pumped again is this correct?and can you flood the motor pumping the primmer on the hose)
its getting fuel & spark and runs great once started
need to do a compression test on it still
this is a new to us motor we picked up off CL
any suggestions would be highly appreciated
