eezerz
Looks great! You do good work man.... =D>
Nick Jones said:Heck of a job! You keep me inspired to finish mine. Wonder who will get their third boat first. lol
Nussy said:My bow has a wood backing under it. Maybe 1/2-3/4" plywood. My plan is to put 4 bolts through it with big washers to give it some extra support. If I were you, I'd just do the same, Cut a piece of wood 2-3 times bigger than the bolt pattern to spread out the load.
jasper60103 said:Nussy said:My bow has a wood backing under it. Maybe 1/2-3/4" plywood. My plan is to put 4 bolts through it with big washers to give it some extra support. If I were you, I'd just do the same, Cut a piece of wood 2-3 times bigger than the bolt pattern to spread out the load.
The extra support sounds like a good idea. My problem though is my bow cover is kinda bowed shaped (i.e. not a flat surface). So maybe replacing aluminum bow cover with plywood is be a better solution. I don't want to get in over my head though. I will think on it some. Sorry, I didn't mean to high-jack your thread. Thanks. jasper
Nussy said:jasper60103 said:Nussy said:My bow has a wood backing under it. Maybe 1/2-3/4" plywood. My plan is to put 4 bolts through it with big washers to give it some extra support. If I were you, I'd just do the same, Cut a piece of wood 2-3 times bigger than the bolt pattern to spread out the load.
I still think you'd be ok doing it. Just don't use as big of a backing or use aluminum to back that might be a little more flexible. Hell, you could probably just get by with washers. I wouldn't hesitate looking at your boat to do it.
eezerz said:Really nice work... She's comin along nicely... I like your TM mount, looks clean(better than wood)...
If I were u, I would take a file to those sharp corners on the TM mount, I'd hate to see you or the kid cut opent there arm or something like that...
I would also mark that plug for the TM motor(12V only) or 24V, whatever power your running through it. You wouldn't want one of your guests plugging in a cell phone or laptop or coffe maker and causing a fire from shorting it out.... I know u know what it is, but, others may not. Especially since you said you were gonna sell it when complete.....
Just my opinion, but it REALLY does look great. GREAT JOB so far....
=D> =D> =D>
switchback said:he screwed a piece of 2x4 on the bracket with 2 countersunk holes where the TM screws down into them.
