Edstrossner
- Joined
- Dec 21, 2014
- Messages
- Reaction score
- 0
I took the intake manifold off the 25 last week with the thought of adding a pair of cone spacers to the reed assembly. After removing the reed plate I noticed that there is a large difference in the crankcase openings. Cylinder #1 has a larger opening than cylinder #2. So, I decided to tear down the power head and rework the block as follows:
Squared the ports with a 5/8" end mill. This did not square the ports that much. I just wanted to get all the ports set at the same height. They were off by .014.
I milled .062 off the exhaust port bottom to match the piston at BDC.
Milled .012 off the block deck
I did a lot of hand grinding in the crankcase area. My goal was to get the crankcase openings at the reed plate to be close to each other.
I also tapered the back of the cylinder wall as it leads up to the transfer ports and knife edged the transfer ports.
The biggest change will be the boost port. I followed the basic idea that Chrysler used in adding a 1" hole to the piston skirt on the intake side and putting a 1" hole into the cylinder wall at the transfer passage way. This should pump more fuel air mix up to the transfer ports.
I still need to match grind the exhaust tuner where it mates up to the block and also to plug the exhaust relief holes in the tuner.
I hope to get the power head re-assembled this week and try it out.
I'll post my results.
