Stumpalump
- Joined
- Dec 2, 2013
- Messages
- 811
- Reaction score
- 3
I used the water based spar from HD. It looks great but it's so thin I put 10 coats on. It still only looks like two coats but it's nice. I moved the side console foward and made under seat storage bins out of Walmart coolers. I could not swing the super nice FishOn brand storage covers. but I scored some clearance ones made for a Zodiac that are nice from the place I found the $25 props I posted in the motor section.
My busted power trim turned into an ordeal but I finally got it fixed tonight! I bought a used assembly from eBay. Motor on it turned out bad but I was able to make one work out of the two I had. I knew it was cheap for a reason but he said it worked. Those old trim units are tuff to work on. I was on pins and needles getting all the leaks fixed and putting the motor and brushes together was a challange. I think sanding the brushes and copper parts they ride on is what fixed it. I mounted my repaired trim motor to the eBay resivior and valve assemble because mine was bad. I think I know why aftermarket trim units are popular now....
