gatorglenn
- Joined
- Sep 9, 2015
- Messages
- 412
- Reaction score
- 0
Yes that’s what I found to. Iam doing mind with drainage in mind though out.Duke62 said:FINALLY! The foam is all removed. Glad I decided to remove foam from rear corners, it was soaked with water and gas. I don't understand Bass Tracker. They pour foam all the way on bottom of bilge area. Any liquid that ends up there can't help but get soaked into the foam. It won't be going back in that way. It will have a gap to allow for drainage. Pressure washed inside. Next is the leak check and rivet repair and then it's coming off the trailer to get paint stripped and trailer reworked.
