1987 smokercraft magnum 161mg rebuild/total nautolex
got the bow framed in also
got all the electrical ran and wires hidden behind the switch/control panel.
took the boat over to my dads heated garage to glue in the nautolex on the sides, I used contact cement for this
cutting and mocking up the side hatches.
3 coats spare urethane on each side for the side panels and back bench area.
side hatches covered and installed
my kids having fun checking out the progress
heres a before and after picture of the outside paint
My dad has the same boat just a sylvan he has a 88 hp spl Johnson and gets around 40mph with 2guys and gear it tubes pretty well too
Were those side vertical hatches already there? They look sweet all covered with new nautolex!
Just curious ... how much smaller than the cut-out is the hatch panel, before covering with the fabric?
You did a really neat job with the corners from what I can see. Did you use monel or SS staples in addition to the fabric glue?
The side hatches are actually custom....there was side hatches on the boat from the factory but the guy I bought it from took them out (he also had taken out the storage around the battery/gas tank area also)and I had absolutely nothing to work with besides a shelf and the wood that was around the shelf. It took be a bit to figure out how I was gonna make them but I am very satisfied with how they turned out.
The hacth panels are probably 1/4 inch smaller than the cutout and they are still really tight so I wish I would've went a little smaller yet but oh well live and learn.
The corners glued completely around the corners with weldwood contact cement and I also secured them with ss staples just to be sure that they last.
I really appreciate everyones comments on the work I've done so far and I will add that this is my first ever boat project so I think it is turning out great.
well I got it all done so here are the remaining pictures of the build/rebuild
gas tank is under the port side door and the starting and trolling motor battery are under the starboard side door
the bow storage is big enough that I can store 2-20lb anchors and the rope for the bow when I launch the boat
console was installed
depth finder, steering wheel and led interior light all installed
couple of the completed interior
I made some vertical rod holders to hold my trolling rods and also added a plier holder and a net holder
I made a windshield out of plexiglass that I got for free. the windshield folds down in the front so when I have the duck blind on it the windshield wont interfere with it.
other things I did to the boat were I replaced the bunks on the trailer and also made some guide on side bunks for it. I added a motorguide wireless 55 trolling motor to the bow that I traded a guy a transom mount trolling motor for even up. Now im waiting on some warmer weather to take the boat for a spin since they have been doing really well on the walleyes on the wolf river for the last 3 weeks
