Worked on wiring most of yesterday, finished installing the switch panel and the fuse panel. Decided to hook up the battery and test it out. All the accessories and the switches work as they should, but then we hooked the motor up to the battery. Made sure that was working, hit the trim, and the trim worked, then we went to make sure the starter would kick and nothing. Tried the trim again and nothing. After some tearing apart it appeared as though we blew a 20amp fuse in the motor. We needed to figure out why though so while this probably isn't something we should have done, we put tin foil around the fuse and put it back in. Power was restored but shortly there after my console developed a smoking habit. After some more looking around there was one wire that was getting extremely hot. After we made some calls to some more electrically minded people we found that one of the wires we grounded was actually a hot wire that shouldn't be hooked up to anything!!!!! Low and behold we tried again now with our slightly melted purple wire just dangling and no longer grounded, and this time no fire and the voltmeter worked!!! So obviously some wins and loses, all the accessories work and we've established all of our hot wires, and have everything working again. Downside some of the stuff we tore apart to look for a wiring issue needs to be put back together which isn't much fun. Also downside, while the trim buttons work to make the hydraulic pump run it isn't lifting the motor. Before winter it was very low on fluid so we topped it off and it was running like a champ, it was also running great before we put it in the garage and nothing has been leaking. So now I have no clue why the trim doesn't want to work. So, in the end, I have a few more wires to run and connect, for nav lights, and graphs both of which are simple, but the major wiring part is done, however I have more assembly to do and a new problem to fix. I guess it's about time I ran into some issues with this build lol.
