hueydr
Decided to strip the boat down a little while it was sunny (had snow flurries and cold). As you can see, it's stripped down to the floor and you can see the styrofoam peeking out from under the walls and floor. The factory didn't do a very good job fitting the foam (sorry Alumacraft) and some of it is wet so I think it's all gotta go. The floor will come up no problem but the side walls are riveted through the hull at the top. I think I will be able to remove the lower rivets and "peel" the side back enough to remove and replace the side foam so that's the plan. I think I will open up the bilge area of the floor a little and put a small pump in. I know I said this was a restoration but I can't help myself. I have a few small updates to make it work a little better for the new owner. No work on the boat this week as I am on a buisness trip (but I will get to go to a BassPro Shop!!).
