bulldog said:
Man this boat is awesome. Great job Jerry.
Thanks BullDog, it has been a very serious effort all along.
Today was windshield day. I used some 1X1 aluminum tubing for the posts, I notched the front two
and had them welded so the front raked back 30 degrees. The rear posts I left alone but shortened
them slightly so they didn't look straight (boring). Here's the pics
bottom of the front frame
bottom of the rear frame
Here is everything mocked up. The blue tape is on the inside where the 3M5200 will squeeze out onto the
Lexan. The protective tape has been removed from the inside. It was left on the outside.
Everything looks good to go so starting with the front, I ran a bead of 5200 down the center of the front
posts and stuck it back in place. Pressing it down until it ran out the edges of the blue tape.
similar to replacing a auto windshield. Next were the two side windows that got the same treatment
carefully removed the tape from inside the front removed the over run and left a nice edge.
Here's everything all cleaned up.
Thanks for looking...Jerry
