- Joined
- Feb 18, 2009
- Messages
- 2,544
- Reaction score
- 2,478
- Location
- Perrysburg Ohio
- LOCATION
- Perrysburg Ohio
Perhaps a bad alarm ??
Ok- ignorance showing (again); isn’t the overheat alarm based on some sensor saying it’s too hot? Would that not be a thermostat?Just to clarify. This engine does not depend on the thermostat much past idle. The engine is heated by the thermostat at idle to promote good idle running characteristics and keep the engine dry internally while running in colder water. The engine is not thermostatically controlled throughout the RPM range. The thermostat cannnot flow anywhere near the amount of water needeed to cool the engine on plane to WOT.
Check your temp sensor also check for sand buildup in blockCold comp test, several times, yielded compression of 125 and 120 for the top and bottom cylinders, respectively. Not bad for an engine that age.
Technically it's a temperature switch... it will either open or close an electrical circuit at a determined temperature this could possibly be the issue as it may be opening or closing at a lower temperature. I'm sure Pappy will chime in on the specifics of it.Ok- ignorance showing (again); isn’t the overheat alarm based on some sensor saying it’s too hot? Would that not be a thermostat?
if warning horn sounds continuously at near or full throttle but engine speed is not affected and If the warning horn stops as engine rpm is reduced, a fuel restriction is indicated. Only when warning horn does not stop when rpm is reduced is an engine overheat indicated.Hello! I bought a "new to me" '91 Bass Tracker Pro 17 a few weeks ago.
QUESTION: Can anything other than a blown head gasket cause the overheat alarm to go off when the throttle is increased past "neutral +" speed?
BACKGROUND: Please bear with me, the background will help. It is a '91 Johnson 40 HP (OMC). The boat was kept in a garage and unused by a widow for over 25 years. Very little use on the motor, but it is over 30 years old (that plastic tip on the manual motor assist also broke). The first use, I took it to the river, warmed it up at slow speed for a bit and opened it up slowly. No problems. Next week, took it to Joe Wheeler with the kids. AM ride no problem. PM ride pulled my son on a tube (He is 130 wet). During the constant throttle changes, it eventually cut off for a minute. Started back fine. Would cut off if throttled too high. Next day, the overheat alarm started sounding when motor put on higher load. No alarm at slow, slow speed. Saturday hooked up motor to hose with attachment. Boat pees fine. Did not throttle high. Sunday went fishing and alarms at any speed past slow, slow. I have the SELOC manual, and it says this situation may be a blown head gasket. So, before I break this down, does anyone have any other thoughts?
Thanks in advance!
Nope. A thermostat is a device that opens and closes as a result of its temperature. It is a restrictor of sorts.Ok- ignorance showing (again); isn’t the overheat alarm based on some sensor saying it’s too hot? Would that not be a thermostat?
I keep Dow 111 vave lubricant on hand for a variety uses around my place.. It is a high grade silicone grease and is perfect for use on rubber/ neoprene and works perfect on pump impellors. I also use it as an electrical coating as it is a diaelectric grease. Make my trailer wiring connections waterproof and corrosion resistant. Just a suggestion here !!I have read some recommendations that you put a small amount of non-petroleum based lubricant on the impeller to help seat it into the housing and "pre-lube" it for first start. Anyone know of any they like? Initially, I thought of using a small amount of olive oil.
Everyone has given great advise, is the pee water hot or cool? Temp sensor may be going bad since sitting for a while but without knowing the water temperature it is unsure. If the water is hot then I would check the engine's thermostat as it may be partially blocked or not fully opening up when engine is warm. Things like this take a moment to run down the list, think of the engine as a car engine as far as the cooling water system only it pees out the water.Hello! I bought a "new to me" '91 Bass Tracker Pro 17 a few weeks ago.
Thanks in advance!
