jasper60103
danmyersmn said:jasper60103 said:jasper60103 said:danmyersmn,
Also, thanks for the detailed pics on the pulley and guide. I'm a little concerned about mounting them that low. It seems too close the water line? I will think on it.
Thanks again.
Second thought, I may just attached the pulley to the floor board.
They are not as close to the waterline as you may think. If you look at that picture you are not looking at the floor. That is the front casting deck. The front deck is resting on top of the bench seats. That's pretty high above the waterline. If you think it through you will find a good way to mount the setup in your boat that works how you want it too.
Ok, I see what you're saying. I may take that approach after all. I don't want the rope to interfere with storage either. Thanks for clarifying.
