Well, the vacation week that I planned to use to get so much done on this project didn't work out as I expected. However, now I'm back in the regular routine, so I should be able to start wrapping things up. I did manage to get a few things done here and there, and it really looks good.
I finished up the bilge cover. The vinyl looks good, but I was a bit off on the thickness of the shim, and the cover stands a bit pround. Nothing ridiculous though.
I also added the rear seat mount. I like the satin black against the vinyl, it looks sharp.
The starboard side panel went on quite well, even with the wiring routing through it. After that I was able to replace the cover over the steering cable and the cover over the warning alarm. I've made an effort to reuse all of the original holes, but in the case of the warning alarm cover, I probably should have done my own. It sits at a slight angle that is going to bother me.
and lastly, I finished one of the seat boxes this week. This was relatively easy and looks great.
One IMPORTANT comment. I ran out of the 3M 90 High Strength adhesive, so I went to get some more. Home Depot had both the 3M 90 High Strength and the 3M 80 for Rubber and Vinyl available. I decided to try the 80, as it should be better for applying vinyl. BAD IDEA. The 80 adhesive doesn't work half as well as the 90. I ended up pulling apart the wrapovers that I had used the 80 on (and they came apart easily) and redoing all of them with another can of the 3M 90. I remember seeing a discussion on another thread about the 80 vs. 90, and I can positively say that the 90 is a far better adhesive for what I am working on.
More to come tomorrow.
