Well it's been a very slow week, with Christmas shopping and wrapping and all of the holiday stuff, I've had a very limited amount of time to work on the project. The rear deck vinyl came out well. Due to all of the panels, rivets and seams in the deck, it doesn't lay very flat, but the texture on the Nautolex hides a lot.
I did try to use a piece of plywood to support the foam insulation that was pressed up against the vertical panel. However when I would start adding some pressure to the board using the angled 2x4's, the whole foam sheet and vinyl panel would ride upward, leaving a large bubble at the top corner. So I scrapped the sheet of plywood and went back to using the 2x4's directly on the foam:
With all of the panels so far, the vinyl has been oversized and then cut to fit after gluing. However, the rear deck design doesn't really allow you to do it this way easily. So instead, during the installation of the vinyl on the rear deck, I used a few rivets through the vinyl to hold it in position and to keep it stretched out. You can see one in this image in the top left corner. I had one rivet in each corner of the deck to hold it tight and in position while gluing. I had my wife stretch and hold the material while I drilled and popped the rivets.
Now, I'm down to the last piece of vinyl off of the roll. It ends up being A LOT closer to the exact amount of vinyl I need than I expected. I took all of the remaining pieces and laid them out on the sheet to get an idea of the fit.
Last night, I glued the two livewell covers. The edge of the vinyl directly against the hinges does not get wrapped. I was concerned about this peeling up using just the vinyl adhesive. So I used some of the remaining 3M 5200 adhesive along this one edge. You can see a little bit of the white 3M on the edge of the vinyl against the hinge.
One suggestion on the 3M is to wrap the tip of the tube with some electrical tape or similar tape and squeeze a bit of the adhesive out when it's wrapped. This allows the extra material that is squeezed out to form a new "Cap" that prevents the adhesive inside the tip from curing. I've used this same tube for over 3 weeks now without any issues at all, even though the tube says to use all of it within 48 hrs.
I also started wrapping the edges of the bilge cover yesterday. I am not planning on wrapping the vinyl under the cover edge, so I'm using some rivets to prevent the material from completely peeling up. I don't trust the contact adhesive over the long term without some mechanical backup method.
After cutting up the last piece of vinyl, I had JUST enough. I would suggest that anyone copying this order an extra yard of material (9 yds instead of 8), as I don't have a single piece of material larger than 10" x 12" left over, and I had to reduce the size of a couple of edge wrappings to make it all fit.
I have a vacation week next week, so I'm hoping to be able to squeeze in a little work among the holiday festivities
Happy Holidays to all!
