PSG-1
scubapro820 said:new engine showed up it is wow clean oem pistons good crank just finishing the re seal for insurance purposes and I have a couple questions, it has v force reeds and ocean pro flame arrestors, I have 135 jets in the carbs but it is an oe size 105 120 135 are the oe options, i do not know if this is jetted fat enough anyone ever run these aftermarket parts and know about what jet size is in the ballpark for this engine?
The jetting should be about 105 for the MAG side carb, 135 for the center, (as it runs hottest).....and then 120 for the PTO side carb. This is what I ran in my engine, and I used Pro-K flame arrestors and carbon fiber reeds.
Yes, I had a lot of previous issues with the center piston having holes blown in it, going through several re-builds. The main problem that was causing this issue was the fact that I was letting other 'mechanics' work on my carbs, trusting that they were doing it correctly.
Once I decided to add carburetors to my list of things I'm able to work on....my detonation issues disappeared. The deto. issue was likely caused by the previous ******* mechanic who had a 155 in the mag, a 105 in the center, and a 135 at the PTO carb. No wonder it was blowing pistons!
Once I ran with the 105, 135, 120 setup, I had no more problems.
The final time the engine died was not because of detonation, but because a 31 foot para-sailing boat threw a 3 foot wake that nearly sank my boat, the engine ingested water, and had catastrophic failure.
So, I would run with what you have, again, do a 'throttle chop' at WOT, then pull the plugs and inspect them, to dial in the jetting. Perhaps go ahead and adjust the high speed screw out by 1/4 turn, so you know it's rich enough, then fine tune it.
Also, make sure that the oil injection pump is correctly synchronized, or you'll have a lean condition.
With the throttle at idle, the hash mark on the housing should line up with the line of the idle setting on the pump actuator arm. At the WOT setting, the hash mark should line up with the high speed mark on the actuator arm. If not, you'll need to adjust the jam nuts of the cable housing where it fits the bracket of the oil pump.
I got rid of most of my Tigershark parts, but I think I may have a few carb jets in the drawer of the toolbox, not sure what sizes they are, but I know there's a few high speed jets, and a few pilot jets.
