Ha, well that reply clearly says absolutely NOTHING ... lol!
So as others have pointed out, their OB manual as written by the Engineers that designed the motor says to "place the motor in gear whilst trailering".
And you? What does your sage advice tell us? Please elucidate us and tell us how YOU are soooooo much smarter than any of us and them?
That's funny, glad to see someone still uses a thesaurus. But I meant no disrespect. You guys are a wealth of info here, and know way more than I probably ever will about boat stuff. But, motors/gears are in my wheelhouse.
However, since you asked. No, not an engineer. But it's my 30+ yrs as a millwright, having visited nearly 1000 factories/shops to work out driveline, vibration, lubrication, alignment, sealing, binding and a host of other problems. I've spent the last 20+ at a plant with over 4500(yeah really 4500)pieces of equipment that a team of us are responsible for. All power transmission systems operate on some pretty basic principles. From 8' herringbone gears that cruise along at 15-20rpm down to 40Krpm spindle motors with ceramic bearing. Same with seals.
Don't get me started about engineers. If not daily, I work with ME's, WE's, EE's, MET's and others a couple times a week. They can and will suggest some of the dumbest things imaginable. Nice people, but MANY are educated well beyond their practical intelligence.
So, the comment about the seal without water over heating due to the prop spinning from air pressure. I would bet you a month's pay that that's never going to happen. The working temps on seals today are between 250*f and 450*f. Neither of which you'll ever get close to with a spinning prop. The 2 temp concerns for seal failure(which cause hardening) are outside temp, underlip temp., where it actually touches the spinning shaft. The other big concern is garter failure, and then all bets are off. If a slow spinning prop could damage a seal, how would the hub seals ever make it to the lake?? Plus, even IF you could cool the seal with water. What about all the thru prop exhausts that are literally trying(and fail) to cook the thing.
Then the comments about cooling with gear lube/oil/... extra bearing wear from the spinning prop. That's not what goes on, how that works. That lower unit lube would be just fine at well over 150*. A temp it would never see without some sort of failure. In all my discussions about bearing failure, I don't ever recall bearing wear on lubricated, ZERO load bearings ever being considered. And that is what we're talking about here, zero load bearing wear. Surface hardening, yes. Bearing seal failure, yes. Wrong lubrication, yes. Lack of lube, yes.
As far as some manuals advising to put into gear I figure it's more CYA than anything else. Some dingdong probably tried to sue them because his lower unit went bad and Mercury never told him to trailer it in gear and that is what caused his problems.
Also someone mentioned a spinning prop on a sailboat creating more drag than a stopped 1. Got anywhere offhand that I can look at that??
So that's where I'm at.
