super_dork said:At this point I'm just going to lieave it and see how she floats
I think you'll be just fine, by the time the treated wood starts eating at your boat you'll most likely have traded up for a larger one
Sgt. Stiglitz said:That's funny, I just ordered that same switch pannel from Overton's Monday I think. It will be here today or tomorrow. How big is the hole for it?
https://www.tinboats.net/forum/viewtopic.php?f=4&t=21376
wwoodard said:Thanks for posting the pic of the back of the switch panel. I hope you don't mind, but I have a couple of questions. Will the red wires with the in-line fuses now be connected to a bus bar, and will the wires that run to whatever is being powered also have an in-line fuse, or is that overkill? Thanks for your help.
I am actually in the process of posting a similar question int he Electrical section of the Forum. https://www.tinboats.net/forum/viewforum.php?f=5. I am not quite sure how it's all going to go togehter. As far as the fuses go, I believe that the fuses on the switch panel are all that are required for the items going to the panel and the red wire will go to the bus bar. The 2 trolling motors won't be attached to the switch. They will have plugs with 50 AMP breakered fuses inline.
