RAMROD
Well last week I found a deal that I could not pass up that included a 15 hp Evinrude electric start, but the pull start had been removed so I have been on the hunt for a parts motor as the pull start assembly is around $200 new and haven’t been able to find one used on ebay hence the cruising of craigslist. Well look what I found! A 1975 9.9 Johnson that was locked up. Well off to take a look I go and it came home with me tonight. Pulled the plugs and the top plug came out with rust all around it so sprayed PB Blaster and decarb in both cylinders, worked the flywheel a little and bam it came free. I filled them back up with lube and pulled the carb off, with the rust I found in the top cylinder I was expecting the carb to be totally gummed but I was wrong! It was totally spotless! Even though it still had the cork float. So I put it all back together sprayed all linkages with PB Blaster as they were all just about stuck but now moving freely. Then I took the air hose and blew out both cylinders, man the crap that came out of the top cylinder, did this a couple times more until crap stopped coming out then check fire and compression, good on both. Put the plugs back in and bam third pull she was running, a little coughing and spitting at first but running just fine. Killed it pulled the plugs blew the cylinders out again and recheck compression, and all good and she fired back up on the first pull! So now will get new fuel lines carb kit & water pump kit. Sorry not going to tell yall what I paid for this one, don’t want anyone mad at me! And yes I am still looking for a pull rope assembly for the 15hp.
Have a look>>>>>>>>>>>>>
