DaleH said:
My biggest boating pet peeves are:
1) Most boat dealers rig the OBs too deep
2) Most OBs are rigged with the wrong (stoo steep) a pitch prop
Ever wonder why dealers do that? Liability. And I have been down that road. Rigged a customer's brand new duck boat the exact same way that mine is, which is conservative but performs well (but not as well as it "could" ). Guy owns it about a week, calls me says it runs like poo after a few minutes of run time. He drops it off, I run it over to the lake, ran it about 15 minutes at full throttle 6000-6050 RPM and never missed a beat. Checked all fluids, checked impeller and key, etc. Found nothing. Told him I couldn't find anything wrong. It's duck season, guy runs it. Brings it back, low compression on top cylinder. Been hot/overheated. I start asking questions and find out that he's running 4 people in the boat, him in the back and 3 in the front. At full throttle it was pulling the foot up out of the water far enough to let the water pump ventilate but he keeps running it because it's duck season and the world will end if they don't have a boat to hunt out of. So in short, we ended up buying the guy a new powerhead. After installing, I dropped the motor back down on the transom (from a 3" lift), which put the AV plate at zero. Trying to get the guy the best performance possible ended up costing us about $1500.
Agree with most guys putting too much pitch in the prop on initial setup. Even Yamaha sometimes suggests more prop than that particular rig can handle. I see it listed on their performance bulletins and sometimes they'll list RPM tested at 5600 or something like that. An inch less pitch would help a ton, IMO, in cases like that. Those performance bulletins are real-world tests that dealers have supplied the info for. Other reason is that if a boat builder/rigger puts an inch more pitch than he knows is optimal, he more or less reduces the chances of over-rev, say, if Mr. Customer decides to ditch a battery or two, the trolling motor, etc...to see how fast it'll go. In the case of 99% of the boats that I've sold, nary a tach gets installed so guys can very easily twist the motor up well beyond what it's designed for. So lot of times we'll suggest using 12" pitch where an 11" would be optimal. Or if they choose 11" we'll tell them that it's optimal with a certain load. Less load=more pitch and more load=less pitch. One prop won't do it all but a lot of people will try. Props are, after all, kind of expensive. I have two. A 11" SS that I normally run, or if my GF and I go together, I'll put a stocker 10.5" pitch back on. Gets out of the hole faster, which is kind of important because she has to take everything (including the kitchen's sink) with her when we go fishin. It don't matter to me much...I'm just happy that she enjoys going.
