panFried
Ill have to checkout the depot, as I am moving on with deck/seat plans while I wait and wait for products to dry/cure. Thanks for the tip.
[url=https://www.tinboats.net/forum/viewtopic.php?p=321281#p321281 said:catmansteve » July 5th, 2013, 2:13 pm[/url]"]Small world, ain't it?
I used sand in the paint on the last boat I put a floor in. Some of it wears off in time, but I think that happens with anything. I put three coats of paint on, first no sand and let cure for a few days. I then scuffed the first coat with a scotch brite and put two more light coats on, sprinkling sand on the wet paint as I went. The third coat was more or less to add a little more texture to spots that didn't look like they got enough sand the first time.
The nice thing about something like SoftSand is you can mix it with the paint. Regular sand just sinks to the bottom when mixed in. I've also heard of people sprinkling rock salt onto the wet paint, then when you hose it down after it dries the salt dissolves leaving the texture behind.
[url=https://www.tinboats.net/forum/viewtopic.php?p=321065#p321065 said:panFried » July 3rd, 2013, 9:58 am[/url]"]Ill have to checkout the depot, as I am moving on with deck/seat plans while I wait and wait for products to dry/cure. Thanks for the tip.
[url=https://www.tinboats.net/forum/viewtopic.php?p=321283#p321283 said:Ranchero50 » July 5th, 2013, 2:26 pm[/url]"]Boat looks really good, when you going to get it wet? Hoping to be out this evening, probably fish from the quarry down but might go up to the islands to swim on the MD side beach at the bottom.
[url=https://www.tinboats.net/forum/viewtopic.php?p=322388#p322388 said:smackdaddy53 » Today, 10:23 am[/url]"]Looks great man! It is scary cutting into a big ol sheet of aluminum but great when it fits with a little trim here and there.
I found that cutting aluminum with a jigsaw can be done but you have to go super slow, have it set to reciprocate at the highest speed and use blades with less tooth count per inch. The aluminum will just stick to the teeth of finer blades especially if you push hard to try to go faster.
[url=https://www.tinboats.net/forum/viewtopic.php?p=322399#p322399 said:panFried » 40 minutes ago[/url]"]Nice job on the cuts. Can't wait to see it the boat.
[url=https://www.tinboats.net/forum/viewtopic.php?p=322443#p322443 said:Ranchero50 » Yesterday, 4:51 pm[/url]"]Looks good. Sadly since I finished painting my hull tan the fish seemed turned off when we were out Saturday evening... Thinking flat black horizontal lines to break up the coloring.
A lawn chair and beer usually helps me brainstorm some of my best work.BigTerp said:...Having a bit of trouble figuring out how to frame out my bow extension. The curve of my hull is making it a challenge. My buddy stopped by last night to help me brainstorm and I THINK I have it figured out.
