bigwave
I have a year 2000 J25RSSE short shaft johnson. Yesterday I put the engine in the water for the first time in two years. After several hard pulls and some carb cleaner I got the motor fired. It was cold and took a minute to rev up and sound normal....I noticed that the pee hole was not streaming and shut the motor off. I then adjusted the muffs and made sure that both sides were on the intake and the stream began to flow.....solid stream......I let the motor run for a couple of minutes and shut it off. I then took the boat to the ramp and put it in the water........The stream was solid again, as I proceeded out of the marina the motor started to run rough and the stream went away.....I tried to rev up and get on plan, hoping it would blow something out to no avail.....turned around and put the boat back on the trailer and went home. The motor did not over heat but I idled it back to the ramp probably 2 mins with no stream or very weak stream. When I got home today I put a piece of heavy mono all the way back to the block.....its not cloged....I am thinking I have a bad impeller since the boat has sat for two full years....I a pretty sure I found the part I need, but I want to know how had it is to take the lower unit off and if I do, should I just change the impeller or should I get the whole water pump kit? I only see four bolts that hold the lower uint on, I was told to keep the motor in neutral and it should just pull right out. Is there anything I should know before I attempt this? It looks easy enough, but my old yammy gave me fits when I took the lower unit off....of course it was completly destroyed but any advise would be appreciated.
Thanks
Kevin
I think this is the impelller for my engine? https://www.marineengine.com/newparts/part_details.php?pnum=SIE18-3051&ptype=&Engine=&Model=
Thanks
Kevin
