Charging question
user 29
I have a G3 1756SC. I was thinking about putting a battery in the storage compartment on either side of the livewell (bow) because I'm unable to run 6 gauge from bow to bilge.
When I charge the batteries, do I need to disconnect the batteries or can I charge them while all wiring is connected? 24V set up
thanks
[url=https://www.tinboats.net/forum/viewtopic.php?p=341400#p341400 said:
muskiemike12 » Mon Feb 10, 2014 8:29 am[/url]"]You shouldn't have to disconnect anything. If you do, your set up is wrong. You just need to have a 2-bank charger.
I don't have a two-bank charger, just a regular battery charger.
You should still be able to charge them w/o having to disconnect anything. But unless your charger is capable of 24v charge rate, then you will have to charge them one at a time.
[url=https://www.tinboats.net/forum/viewtopic.php?p=341436#p341436 said:
JMichael » Yesterday, 15:51[/url]"]You should still be able to charge them w/o having to disconnect anything. But unless your charger is capable of 24v charge rate, then you will have to charge them one at a time.
+1
