Hey all new to the site form the PNW with a question regarding a recent install of an aftermarket tilt trim unit.
Mounted on a 2015 starcraft Alaskan with a 20 hp Yamaha hanging off the back.
Added the trim tilt plate over the top of the screw heads that secure the transom support to the transom.
When mounting, the plate sucked up to the edges where the screwed weren't but appear to have deflected the transom inward where the screwed heads are proud of the skin.
I woke up thinking I should have added spacers so the bracket floated above the screw heads.
I am worried about damage and wonder if I should reinstall with spacers or let is sit as is, thinking the on/off pressure then a no pressure may me worse.
First tin boat and a little leary.
Thanks for any assistance
